My daughter is in school in Baltimore, MD and her ‘97 P38 4.6 decided to shut down on her while driving. A quick check appears to show that there is spark, but no fuel. Had it towed to a garage nearby who are pointing to the crankshaft position sensor, but that can’t be right if there’s spark. The fuel pump was replaced a few years ago, but that’s no guarantee it hasn’t failed again. So, looking for a shop that understands the P38 is anyone has a suggestion. Thanks.
1995-2002 Range Rover Classic
no fuel and good spark could be a clogged fuel filter or the fuel cut off solenoid on the passenger kickpannel, sorry I'm in Va, nearly 70 miles away from Balto Md. Can't help with shop info other than suggest dealer tow. in a curious odd circumstance, if you needed a shop in L I NY I do have info on at least one.
I'm from just north of Baltimore (Harford County), although I do most all of my own service, I would recommend Holzhauser's Auto Service in Aberdeen, MD. They did my coil conversion last year. (410) 272-1170
You could also try Raspi's British import specialists in Edgewood, MD(410) 420-1202
Hope this helps
Those are two possibilities for sure. Thanks for that.
Who’s your go-to on LI?
Hope this helps
It just may end up in Aberdeen. We’ll see how it goes. Thanks for the names.
