I've been able to use a CCF editor and push my changes to my 2017 L405 without issue until the other day. I finally wired in a ACC radar and went to enable adaptive cruise and the Select CCF routine fails almost immediately. I checked the Pathfinder logs and saw the error listed below. What's odd is that my current file will push to the vehicle without issue - this file has been edited dozens of times so it's very confusing as to what is the cause. Please respond or PM if you can help!
av - Error executing flow
java.nio.BufferUnderflowException
at java.nio.Buffer.nextGetIndex(Buffer.java:500)
at java.nio.HeapByteBuffer.get(HeapByteBuffer.java:135)
at com.avl.ditest.dicore.diflow.flash.VBFHeaderParser.a(SourceFile:98)
at com.avl.ditest.dicore.diflow.flash.VBFHeaderParser.parse(SourceFile:27)
at com.avl.ditest.dicore.diflow.flash.FlashDataVBF.a(SourceFile:77)
at com.avl.ditest.dicore.diflow.flash.FlashDataVBF.getSegments(SourceFile:54)
