Hello, I have new end links for my front end but I cannot for the life of me undo the nuts on the old ones. Turns out that the top nut is not quite tight causing a noise but I cannot tighten it .So can't loosen, or tighten the nuts. Sprayed all kinds of anti seize, applied heat, nada.
Anyone had this problem and found a way to fix it?
TIA, arby
Discussion Starter #2
One side off. Angle grinder. Need new nuts and washers.
