Hi All,
I wouldn't ask if it weren't important!
Work done:
* New compressor fitted and teed into the blue line to the valve block in the EAS box
* Valve fitted between oem comp and new tee, to stop air escaping back through the oem comp when running the new.
* New valve block and driver pack
* I just checked all the pipe connections to the valve block for location
* both compressors work (not at the the same time, of course).
* no faults showing on the display
* said my prayers nicely
Problem:
* the reservoir doesn't seem to be filling - I left it maybe 10 minutes and the car doesn't lift at all.
* I have tried both compressors, and now back to OEM.
What do I check now?
Could I have messed up one of the multi connectors in the eas box?
I thought that the reservoir took about 10 minutes to fill .....
Work done:
Problem:
