Hi all i have just loaded SDD software using Drew Mongoose Pro ada[pter.
every thing loads upto final screen when put VIN No in it accepts press enter
then machine just hangs any ideas.
Try first the cable with another laptop on winxp to be sure mongoose is working.
And battery voltage is also important
Than you can try another files to crack
Check that it says mongoose connected lower screen right corner.
If not connected did you load the mongoose drivers.
Can't be much more help I'm afraid, mine just stopped working as it says needs updates, but I have been warned not to update or go on line while using SDD
Probably needs a complete reinstall
