Hi all.
I have a 2005 vogue td6 l322. I’m having a problem with rhs screen water jet, comes out great on the lhs but nothing on the right. I’ve checked to make sure there are no blockages so what is the next step? Any help greatly appreciated.
thanks in advance
Hayden
Not sure what you've done to check for blockage, but totally suspect that's the problem. One pump feeds both spray nozzles. Single line branches to two nozzles. I use a single wire from a wire brush, using a hemostat to run down the nozzle to ensure clear. You can disconnect lines and blow out with air. Little doubt that you have simple blockage.
Sent from my SM-G920V using Tapatalk
Disconnect it and make sure you have flow through the hose. If hose flow is fine then replace the washer as it is most likely corroded. You say there are no blockages... obviously something is blocked or it would be working.
