Scale of 1 to 10 on removing body from 1990 Classic
844 Views 2 Replies 3 Participants Last post by  95classiclwb
On a scale of 1 to 10, how hard is it to take off the body from the frame? I want to completely go through this vehicle. Got some corrosion on the chassis, so I want to clean it up. Also do some suspension work, engine work etc... If anyone has done it, some tips would be greatly appreciated.
It’s not too bad I re chassied my classic 5 years ago. Don’t forget the rear seat belt anchors are also holding the body to the chassis.
it takes about a day to remove, longer to install. as mentioned above there are a few anchors in the middle of the chassis 10 supports, fuel tank neck cooling and heating (ac/and heater lines) radiator, steering lines and shaft, transmission lines, shifter cables, electrical. lifting is best achieved if you have access to a lift as the body needs to be between 3 and 4 feet off the frame to clear. been there done it a few times.probably a 7, if 10 is the worst.
