1 - 1 of 1 Posts
Does anybody know if, and when the fan should run in the MkIV Sat NAv unit?
Mine has started to refuse to read the DVD when it's hot. Investigation on the BMW forums suggest that the laser is on it's way out, and this is a common occurance. Now having changed the laser sledge, the problem has re-occured.
My thinking is that if it heat related, and I've changed the suspect, then could it be a general build up of heat as a result of the fan not functioning.
Any thoughts.
Many Thanks
John
1 - 1 of 1 Posts
