1 - 1 of 1 Posts
Number of results found: 10 - Search executed on year: ALL
Year - Week No.
Ref. Notifying country Product
(Click on the photo to enlarge) Danger Measures adopted by notifying country Products were found and measures were taken also in:
2010 - 2 27
0027/10 Poland
Category: Motor vehicles
Product: Passenger car - Defender
Brand: Land Rover
Type/number of model: Vehicles made from 7 June 2007 till 13 February 2008. VIN numbers: LD 740135-LD 757662, LD739991, LD066843-LD068528.
Description: Passenger car
Country of origin: United Kingdom
No picture available
Injuries
The product poses a risk of injuries because transfer box oil contamination of the park brake shoes and brake drum may mean that the park brake when engaged will not hold the vehicle stationary on a gradient leading to an accident.
Voluntary corrective actions taken by the manufacturer.
Ireland
Iceland
2009 - 41 1
1350/09 Greece
Product: Passenger car - Land Rover Discovery and Sport
Brand: Land Rover
Type/number of model: Discovery 3 TDV6 Diesel and Sport TDV6 Diesel
Description: The recall is specific to 2007-2008 model year Discovery 3 and 2007-2008 model year Range Rover Sport vehicles with the EU4 TDV6 engine, with VINs from:
- LA412125 to LA487033 (Discovery 3),
- LS100008 to LS999998 (Range Rover Sport).
Fire
The product poses a risk of fire because fuel may leak via the fuel pump front seal onto the rear of the engine or onto the ground under the vehicle and could catch fire.
Voluntary corrective actions taken by the importer.
Netherlands
Denmark
Austria
Malta
Slovenia
Spain
Sweden
Iceland
Bulgaria
2009 - 33 52
1201/09 Poland
Product: Passenger car - Land Rover Discovery and Range Rover Sport
Brand:
1. Land Rover
2. Range Rover
1. Discovery 3
2. Sport-EU4
Description: Model year 2006-2009
1. Land Rover Discovery 3 – VIN numbers: LA 367110 – LA 513325,
2. Range Rover Sport - VIN numbers: LS 929086-LS 999999.
Cars made from November 2005 till April 2007 and from May 2007 till June 2009.
Injuries
The vehicles pose a risk of injuries because:
- vehicles produced between November 2005 and April 2007: Engine oil may migrate from the engine to the brake system causing a progressive loss of braking assistance. In extreme cases, engine oil may migrate to the brake master cylinder, leading to a total loss of braking.
- vehicles produced between May 2007 and June 2009: A temporary sticking of the vacuum non-return valve in the brake assistance vacuum pump may lead to a temporary loss of breaking assistance.
Slovenia
Greece
Malta
Spain
2009 - 29 31
1013/09 Germany
Brand: Land Rover
Type/number of model: Vehicle type LM, EC type-approval e11*98/14*0185
Description: Passenger vehicle.
Country of origin: Germany
Injuries
The windscreen is inadequately secured and there is the possibility that it may become detached in the event of the vehicle suffering a severe impact, increasing the possibility of injury to the occupants.
2008 - 43 1
1230/08 Greece
Product: Electric booster heater in passenger car
Brand: LAND ROVER
Type/number of model: model Freelander 2 Diesel (programme number P011)
Description: The recall is specific to 2007 to 2009MY Freelander 2 Diesel vehicles fitted with an electric booster heater. VINs from H000100 to H111695.
Fire
The product poses a risk of fire because condensation from the air conditioning evaporator mounted in the air conditioning unit can come into contact with the control circuit for the additional electric booster heater; resulting in a short circuit. This would normally cause draining of the battery which will eventually go flat, leading to a non-start situation.
Additionally, the short circuit may lead to a distinct smell from hot and/or melted components which, in extreme circumstances, may develop into a fire inside the vehicle. All of these symptoms can occur either when the vehicle is in use or parked and unattended.
2008 - 11 4
0333/08 Greece
Brand: LAND ROVER
Type/number of model: Passengers’ cars, model Freelander 2/LR2 (program number P009).
Description: The recall concerns 2007 and 2008 model year vehicles, with VINs from ?000201 to ?087347.
Injuries
The product poses a risk of injuries due to possible loss of the glass panel of the sunroof.
Failure of either the left-side or right-side sunroof guide rail could cause the sunroof to become detached from its operating mechanism and bind. There might be a cracking noise if this condition occurs. If it does occur, the sunroof glass panel will remain attached to its frame, but further attempts to operate it will result in continued noise and abnormal operation due to the binding condition. If a vertical force is applied (for example, if the user is manually aiding the sunroof to close, or wind lift) the glass panel can become fully detached from the vehicle.
Voluntary corrective action taken by the manufacturer
2007 - 15 6
0341/07 Greece
Product: Passenger car (fuel tank, vapour recovery system)
Brand: LAND ROVER
Type/number of model: Passenger cars, Discovery 3 4.4V8 gasoline vehicles. Model years 2005 and 2006 with VIN numbers from 5A342834 to 6A359153.
No picture available.
Injuries and fire
Some of the affected vehicles may contain a breather pipe that was not manufactured to specification. This may result in excessive swelling and cracking of the retaining grommet and subsequent detachment of the breather pipe from a connector tube. When the fuel level in the tank is above the level of the detached joint, fuel may then enter the breather pipe. The vehicle may exhibit MIL illumination, fuel odour and drivability concerns such as hesitation, misfire, stalling, rough running or difficulty in starting (reasons for probable cause of accident). If the amount of fuel flowing into the breather pipe reaches the vapour canister and exceeds the canister capacity, the excess fuel may be discharged onto the ground (possible cause of fire).
2006 - 29 4
0447/06 Spain
Passenger car Land Rover 4x4
Type/number of model: Range Rover Sport LS
Country of origin: United Kingdom.
Click on the picture to enlarge
This product poses a risk of injury.
The clip on the front left wheel balance weight may chafe against the brake hose, ABS sensor or brake pad wear sensor. If any of these situations occurs, the driver will have to press down further on the brake pedal, increasing the braking distance and the brake failure warning light or brake pad wear warning light on the dashboard will come on. If braking effectiveness is reduced, this could cause road accidents, irrespective of whether the driver is alerted by the brake failure warning light or brake pad wear sensor light
2006 - 29 12
0455/06 Spain
Passenger car LAND ROVER
Type/number of model: Models: RANGE ROVER, RANGE ROVER SPORT and DISCOVERY 3.
These cars pose a risk of injuries.
The gearbox may fail to lock when the gearshift lever is put into the parking position “P”, which could lead to the vehicle moving if the handbrake is not activated.
In the case of the Discovery 3, in addition to this defect, the vehicle is equipped with xenon headlights without the system of automatic dynamic height control that is required by law. The rolling away of the vehicle when in the parking position may lead to collisions with other vehicles or pedestrians and cause traffic accidents. The lack of automatic dynamic height control for the xenon headlights of the Discovery 3 could reduce visibility for the driver or blind other vehicles, thereby increasing the risk of accidents.
2006 - 16 2
0222/06 Spain
4x4 vehicle "LAND ROVER"
Type/model: DISCOVERY 3 and RANGE ROVER SPORT.
Risk of injury. In the notified cars possible reduction may appear in the restraining capacity of the left-hand safety belt in the second row of seats. This might not sufficiently restrain the person occupying that seat on vehicle impact or sharp breaking.
Voluntary corrective actions taken by importer.
1 - 1 of 1 Posts
