1 - 10 of 10 Posts
My new safari fogs blew out one circuit for a low beam, need this part from under the passenger seat... anyone got one?
Which BeCM do you have? More importantly why on earth are your safari lights wired to pull power form the lighting circuit?
I would suggest getting a hold of Scotty.
yes... huge error at my shop.
Bosch, 01- would parts from the GEMS not be the same for this little board?
This little board? The headlights are controlled through the BeCM...
I was told I need one small part that is within the BECM... I do not need an entirely new unit, but I can go that route if I need to. Guess it requires reprogramming etc
It all depends on what failed. Unless you are doing solder, work there is no such thing as a "one small part". Someone with no experience in BeCM workings and repair would be replacing the entire power board. However we would still need to know which variation of the BeCM you have to be sure. I still suggest contacting Scotty who can repair what you have or if something is seriously fried he can advise further.
Discussion Starter · #7 ·
thx.. scotty has chimed in to me. I have some local rover techs who can dive in and try to fix the board. I do know of Becms selling for 200... so hope to beat that in labor on this fix
You might want to think your pricing. Buying a BeCM for $200 does not include cloning/programming.
Sounds like it's just a MOSFET that's failed. They are pretty easy to replace, trying to get working ones off a board are a bit of a pain, but removing a dead one to replace it isn't as bad. Definitely fixable.
1 - 10 of 10 Posts
