1 - 20 of 23 Posts
2010-2012 Range Rover Sport
RRS L320 2011 , No start , No crank "Smart key not found"msg
Hello
Greetings
I have an RR sport that came with a sudden issue , It won't start at all , No response from start/stop botton , At the Instrument
Cluster it indicates that " Check Smart key " or "Smart key not found " , I believe this is a common issue which incorporates software
updates at the KVM " keyless vehicle module" , All i did i've plugged a scanner , fault code entry at the BCM " Body control module "
which states " B1009-62 Ignition authorisation " .
My question is : Is this fault code related to the kvm software update or its an internal failure in the BCM ?
Any appropriate advice would be appreciated
cheers
2013-2015 Range Rover Sport
Re: RRS L320 2011 , No start , No crank "Smart key not found
Does it start when you hold the key under the steering wheel, as noted in the manual? Might be something simple like a dead battery. How about the other key?
Had same issue. Dead battery. Had it replaced by LR Dealer. No more issues.
2013 RRS SC
This always makes me laugh. Let's scan codes and do all this stuff when the truck tells you flat out to check the key. Go spend 4 bucks on a new fob battery and see what happens
Both key fob batteries are in perfect condition ,
Discussion Starter · #6 ·
It doesn't start either , Under the steering wheel where the immo antenna is located ,
Thanx for the kind reply , Actually i know what's going on , But all i want to understand is the code ,
if it's related or not . thanx alot
Discussion Starter · #7 ·
Key fob battery or the Vehicle batt ?
Check the similar threads, below to fix your truck.
And if you know what is going on, how about enlightening the rest of us.
OBTW: where is Lyb (Lybia?)
Discussion Starter · #9 ·
All went good , Thanx alot
Discussion Starter · #10 ·
Changed the batt , reprogrammed the keys to the immo , Thats what was popping up the code in the BCM ,B1009-62 , So the "truck" started fine ,:mrgreen:
Hello,
I have the same problem on 2011 RR SC, not even underneath of the steering wheel too..what was the issue and how did you get it fixed?
Please help, just bout it few months ago and its stuck in my drive way...
Thank you
Well according to the post above yours he changed the battery. :roll:
Remember rocket scientists. that just because you just purchased a new fob battery does NOT mean it is "new". Those batteries can sit on the peg for ages before someone comes along and buys them. Always take a battery from the rear of the peg... FIFO. When all else fails reference post #4 above.
Wait: he also reprogrammed the immobilizer. Not sure how that is done on this series of Range Rovers, on a Jaguar x308 it was a trip to somebody that had dealer level software.
Well as the keys come preprogrammed he most likely meant that he SYNCHED the remotes. Anyone can synch, no body can program. There is a big difference and the terminology is almost always misused.
Discussion Starter · #15 ·
Before any procedure regarding relearning or synchronization of the existing keys ( if it's a must ) , the voltage source must be in a perfect condition .
Google translate: Put new batteries in your key fob
Discussion Starter · #17 ·
Already did , didn't solve the issue .
You are confusing me to no end: does the truck start now? Yes or no? Did you have to have the key transponder reprogrammed or was some other part programmed. And where is LyB?
And where is LyB?
Libya. As with stores in any location we have no idea how long those batteries have been in the store. There have been countless members that have returned drug store and grocer micro batteries because they were duff right out of the package. It's happened twice with my personal remotes and numerous times with folks that bring their rigs to me. Seriously, buying a second set of batteries is either going to fix the issue or provide a back up set of batteries. It is known issue that is cheap to check.
Discussion Starter · #20 ·
Sorry for confusing you , But The issue was already sought and solved , It was a communication problem between the key and the CJB that required relearning of the keys , the truck starts fine now , I was just stating that changing the key batteries didn't do me any good for my case that's all ,
1 - 20 of 23 Posts
