Mornin' all,
After several months of procrastinating, I finally bought a Range Rover last month.. it's a 1993 LWB in blue with an OME spring conversion and (I guess) 2" lift. It had sat for a while.. the fuel pump was dead, the heater core leaks, and there was about 1/4 turn of play in the steering. Having fixed all that, it's truly superb.. and my attention turned to what I wanted to use it for... ie, pulling trailers of rusty MGs and Triumphs around the state.
I (foolishly!) assumed all Range Rovers had trailer hitches - but mine doesn't. Looking under the back (where the hitch should be!), there's two holes in the floor (about 2ft apart) and a square cutout in dead centre. It looks *to me* like someone took an angle grinder to it and literally cut the old hitch off.
After I got past the inevitable first question (why would anyone do that ?!?!?!), the next question that occurs is "can I replace it?". I know the hitches on later Range Rovers (and Discoveries) just bolt on to the chassis, but it looks like the earlier ones (ie: mine) have it more permanently fixed in place.
So.. my question.. is that right? Can you really not replace the hitch received on a '93 Range Rover? Both the local custom hitch places round here wouldn't touch it.. so I'm kinda stuck.
Any advice/pointers very much appreciated!
