1 - 15 of 15 Posts
I've been intending to do this for at least six years and I'm finally getting around to doing it. More accurately, my local shop is getting around to doing it. They procured a new rear crossmember (see below on top of Uline bin) from YRM Metal Solutions and it looks great. They're also replacing the loadspace floorpan and two inside panels.
292900
Leftside crossmember
292901
Rightside crossmember
292902
Left inside panel rot
292903
Rightside floorpan seam rot
292904
1989 Range Rover Classic
Looks like quite the job! YRM Metal has great stuff, they had all the weld-on brackets needed to convert my pre-sway bar rangie to sway bars, it's awesome that they make so many components for classics.
I've never heard of them, but I'll definitely look at their website now. I had no idea the rear crossmember was being reproduced, mine has some rot on the exhaust side but not dearly so bad as yours, but it still concerns me. Thanks for the posting, let us know ow it goes.
Sorry, what year is your rig? Not a '93, mine is the same color, a LWB, and I have the white wheels.
Mine is a '95 RRC SWB, born in Jan of 1995. I also had a '95 RRC LWB, but that was born in 1994. ISTR, only the SWBs were made in 1995, but the 1995MY was a transition year, as the P38 debuted in 1995, so there were two Range Rover models offered, and two wheelbases for the RRC. At least that was the case in NA. In the ROW, the softdash was a 1994MY.
There are several threads on the RRC rear crossmember replacement. Don't be fooled, the rear crossmember may appear to be solid, but these rot from the inside out. If you press the crossmember with your finger and it's mushy, you have rot. I discovered this on mine about a decade ago, but I dragged my feet on making the replacement project a priority. In the past year, lowering the liftgate made me nervous as the rot was more pronounced and the hinges were feeling less than solid. I could procrastinate no more...
Enjoying this thread. May I ask who/where is doing the work? I am on the hunt for a similarly-capable shop.
Discussion Starter · #6 ·
It’s a sub to Independent in N. Bethesda, MD. https://www.indlr.com
The body shop is actually out in Beltsville.
Still waiting for load space floor pan to arrive from across the pond...
Discussion Starter · #7 ·
Some progress pics...
294286
294287
294288
294289
Discussion Starter · #8 · (Edited)
Some pics closer to the end...
294290
294291
294292
294293
294294
294295
It's almost a shame to cover this with carpeting, knowing what it was like for more than a decade...
Are you considering adding some sound/vibration deadening before the carpeting, since it's all already out? I added dynamat through the whole load bay (sides too) and it did a good job of dampening road noise. I'm planning to add some to the doors and roof too.
Discussion Starter · #10 ·
That's the plan, especially since the OEM padding is a sponge. I'm hoping the Dynamat will be less sponge-like, but I really shouldn't be expecting any moisture now that all the floor panels have been replaced and the wheel well rust mitigated. But then again, R.U.S.T. does stand for Rover's Unreliable Steel Treatment...
Discussion Starter · #11 ·
So the loadspace has been buttoned up and back to a solid condition. I can actually stand or sit on the tailgate without fear of it snapping off. Pandora still needs a lot of work, mostly cosmetic, but the tailgate lettering is really annoying with two letters missing. I thought I found a source at Famous Four, but they don't have the thicker decals for the softdash. I may have to engage a local sign-maker.
I am ok with not repairing the ripped vinyl strip between the tailgate and loadspace. I plan on taking care of that when I do the frame-off resto, hopefully, that won't need to start for a few more years.
294553
294554
Really happy with the new headliner. That sag in the rear was really annoying. Now I just need to replace the central locking module, rebuild the seat ECU, replace the HK speaker grill on the front passenger side, repair the center console bezel that's disintegrating, reskin the skateboard, etc...Never ending RRC projects...
  • Like
Reactions: LanceL
Looks great!
Discussion Starter · #13 · (Edited)
Both my interior lenses are yellowed, one had a hole melted through by the lamp. About five years ago, I had ordered a new lens but never bothered to put it in, as I had planned on addressing the sagging headliner. So the replacement sat in a bin in storage. I finally found it, but when I opened the package, I discovered it was cracked on the side. Ah Sh*tpart...I guess it's ventilation?
294582
Another thing that's been long neglected, cleaning and conditioning the Connolly leather. I actually have some official LR leather cleaner and conditioner from over fifteen years ago, so I cleaned and 'greased' up the Connolly...
294583
294584
No more sagging headliner...
294587
Discussion Starter · #15 ·
Finally got around to changing the interior bulbs to LEDs, new lens from AllMakes. Much brighter and less likely to melt the lens.
294722
294723
1 - 15 of 15 Posts
