Does anyone successfully use a 2 post ramp to work on their RRC? I appreciate the jack points are diffs and axle beams not cills - do 2 post lifts work ok without having jack points on the cill sections?
Yes, use the frame rails. Had my on one while replacing all the suspension bits.... bushings, springs, tierod ends, etc, didn't have any issues. Might take a few tries to find the balance. Take your time!
If EAS is still intact, you should stick with 4 post only. Otherwise, I see no reason not to use a two post. Without EAS, there are no airbag sleeves to worry about.
the lower sills is a good place, use rubber pads or wood. other wise your lift need the pad raisers/ adaptors so the legs can clear the lower control arms. another lift point is the chassis mount where the radius arms mount to the chassis.
I use my 2 post lifting on the frame rails. it was a bit spooky for me, so I pull up my Bobcat and lift the bucket till its cradling the rear, extra security. i did have to fool around with various combination of the adaptors to get it to sit flat in the air.
