Hello everybody,
I am currently looking for a new automatic zf 4HP22 gearbox for my 3.9L 1989 Range Rover Classic as the old one has broken down.
I have now come upon a 4HP22 gearbox that was taken from a 3.9L 1995 Discovery 1.
Are these directly interchangeable?
Thank you in advance!
1995-2002 Range Rover Classic
yes, the difference may be the torque converter style as disco 1 had 2 styles thru the years.
the image is the style with the built in spacer, you can install this style with the respective flexplate if available, or retrofit by installing the converter fitted to a classic. if your new transmission has the round style with out the spacer it's a bolt on fit.
