Hello, i have noticed a white smoke puff while gear shifting up only from the first to the second gear and second to third gear. It is an 88 rrc with carbs and 3.5 engine. Could it be that the engine needs rebuild?
Thanks Faro
Hi, there is not white smoke when i press the clutch to change gears. There is white smoke puff only when i change the gear up and after i release the clutch (there is no white smoke puff while down shifting). While on neutral ( car is not moving) there is no white smoke.
when i cold start the engine there is white smoke but not too heavy but i believe this is normal due to cold engine start up.
