Hi all;
the steering wheel pump is leaking oil from the hoses connections on it . can this be repaired by putting Teflon tape and silicon then tight them.
because my mechanic mentioned to me that iit is hard to find o-rings for these hoses ( there are 3 hoses connections on the steering wheel pump).
thanks Faro
To replace the hoses or replace the orings. if it is reeally is just the orings, replace them properly. if is leaking where the rubber is crimped to the fitting replace the hoses. UK suppliers should have both in stock.
