Well I have a RR S, TDV6 2.7 Diesel. last year I broke the motor after a bad hose was broke, because i removed the hot water of the heater, (u dont need, is hot over the year) so I have overheating problem that result in 4 cil failure, cranckshaft bearing. I spend like 18 month the car in the garage, after I bought all the part in UK. lot of pain. the car was completed engine rebuild and new harness, beautifull work. but star thee madness began. the car starts, sometimes it does not start and sometimes after a while it stops.
to gone through several engine scanner, no code fails, and the key is carried by several locksmith and everyone tells me that the chip is good, the pressure of the diesel has been measured, the ecu has been checked, the parking sensor.....etc etc to such an extent that I had to rebuild the starter motor. Someone will have some idea, maybe it's silly.
JACK'S GRANDAD
You posted in the wrong forum.
I'd move it, but gave up my admin status after repeatedly banging my head against the wall with the site owners ;)
Martin
