2010-2012 Range Rover Sport
I own a RR Sport 2012 and I got a rear right tire sensor on last night, after checking the pressure, it shows was at 34psi, so I put some more till 37psi.
After driving 20 miles the sensor's light is still on, I checked all other 3 tires and they were fine around 37/38 psi.
The computer still shows the light for the rear right tire problem...wont go away.
Anybody has the same problem?
Thanks for the help.
Sal
It could be that your tire pressure sensor for that tire has failed. I have had two fail so far on my 2014 Chev Silverado half ton so it’s not unheard of for a sensor to fail. You could take your vehicle to a tire shop and see if they can try to initiate the pressure sensor. If they can’t they can probably replace it for you.
