1 - 9 of 9 Posts
I don't know what button I pressed but basically my range rover started to rumble. When I parked my car it dropped way low. How do I get it back to normal height.
Press the suspension up button. No clue what you mean about rumble though.
When I drive it lowers and starts shaking. I think it went on crawl mode how do I get it out of crawl mode and put it back to normal height. Thanks!
It would raise by itself if it were in crawl mode.
Do you have any messages on the dash?
The rumble sounds like hill decent is on - turn the terrain response dial to road (full anticlockwise) ensure Hill Decent is off and height at onroad height.
Sorry without more detailed information I cannot offer any other suggestions.
Garry
Message on the the read "SUSPENSION WILL LIFT WHEN SYSTEM COOLS".It never lifted though. Rover just dropped real low when I parked it. I pressed the button to lift and it doesn't do anything. I feel like I pressed something and it just locked.
You have an error warning pointing to a failing compressor. Most likely you have a leak in one of your front struts and your compressor has worked overtime to keep air in the system. THis is certainly not a case of pressing a wrong button.
My first reaction after just reading the subject line was "Viagra" but I see now that this would have been wrong.
SUPER MODERATOR
Yellow button...not blue!! :)
1 - 9 of 9 Posts
