rough idling
652 Views 1 Reply 2 Participants Last post by  RRToadHall
hi,
Wonder if anyone one can help. the breather pipe that the hose connects too on the rocker cover just pulls out. Is this correct, I am assuming not, and its a possible cause for my rough idling.
the pipe pulling out of the rocker cover is definitely not appropriate. You pull the hose off pipe in order to service the oil separator in the metal tube. Is the pulling out or is it falling out. It's only pressure fit
BTW: add your location to your pro file and your Rover info to your signature
