Hey guys,
Recently I had a rough idle on startup, which seemed to possibly be a cylinder missing. In the past as soon as I got some RPMs going it smoothed out and didn't return. Slowly over time the issue started to return when stopped at lights for a long period of time and such. Now it's happening all the time. I'm going to pull the plugs tomorrow but does anyone have any early suggestions?
A couple things to think about:
  • I replaced the head gaskets just over a year ago.
  • Spark plugs and leads where also replaced then.
  • I am loosing no coolant
  • I appear to be burning none but the look of the exhaust.
  • I have not tested the coolant for hydrocarbons but no bubbling is present.
  • I have no codes, except one for an o2 sensor, which I've been meaning to replace for some time.
Could it be just a coil pack or is that wishful thinking? What would be your next steps after pulling the plugs?
You’ve got it right, go down the list, don’t rule out parts already replaced , leads especially, do the night check to see if any sparks anywhere.
you might want to add year and engine to your post.
Yeah I ordered new leads and coil packs because they are actually pretty cheap. I'll update this post when I have the fix!
Rover is a 1996 4.6 I'll add that to my sig, thanks!
So an update, I replaced the coil packs and plug wires. Unfortunately that wasn't the problem. So the next step for me is to replace the plug. I probably should have started there but oh well. If it's not the plug I suppose I find a way to test the compression and ejectors.
