Should be getting a 2nd hand set of side steps shortly. They have the brackets, but will need some rivnuts for the chassis. Have been told they're a strange type and only available from the stealers for stupid money. Found this which seems to agree.
Anyone know of any alternatives??
Rogan, They use 10mm rawlbolts which is why the brackets are made with a built in spacer. You'll see what I mean when you see the brackets. I have had three P38's with sidesteps and they have all been the same fixings. I can't seem to make sense of that link.
I bought aftermarket side steps (Westin Sure Grip) and fabricated custom brackets. I used the factory mounting points,the holes in the frame and 5/16" rivenuts. Unfortunatly 5/16 is slightly too big and required a few hours of grinding, filing the holes out. Some holes are easy and some are near impossible to get to, require a rt angle drill and shortened bits. It does seem strong now that its all done, I wasnt sure the rivnuts would hold but if its good enough for the factory , I guees its good for me
http://cgi.ebay.com/Rivet-nuts-rivn...439a2a306b&_trksid=p3286.c0.m14#ht_500wt_1182
David
Discussion Starter · #6 ·
Spoke to Morris, they feed a nut and washer into the chassis and bolt into it. Just went and checked my car to see how easy that'd be to do.
Huge result, someone had sidesteps on before and rivnuts are already there. Just need some M8 bolts and washers now according to Rave.
