hi i have an 01 4.6 with 18" rims can i replace these with a set of 225/40 zr18 if so wil there be any difference in performance or will i have to do any modifications
thanks
Your overall diameter will be about 4" smaller - don't do it.
Do you want lower profile tyres? If so you will need bigger rims.
Correct,
only positive thing will be that the truck will be a lot quicker, but will look sillier.
luvs2getmuddy said:
Correct,
It would accelerate faster but have a lower top speed and use more fuel.
jaysky25 said:
is there any other size that i can put on my truck without looking silly or should i just stick with the 255/55r18
The stock tyre diameter is 29". If you want lo-pro tyres you will need bigger rims to get back to that 29" diamter.
So a 255/50r19 would give you that 29" diameter. As would a 255/45r20.
Incidentally the L322 Range Rover runs on 30" tyres, 255/60r18, these will work on a p38.
Width wise, I believe you can go anywhere between 235 and 275. 275 assumes you buy a low pro tyre.
You might wish to search this forum for tyre related threads.
JK25.
Do you want to transform your truck into a low-rider to cruise the back streets of New York or drive in high mode everywhere ?
If you want to go the low-rider look than only Dunlop offer a specific tread pattern in a 235/50R18 size which is 2 inches smaller.
Otherwise stick to the original factory specification, including load rating and speed symbol so your car insurance is not invalid !
Cheerio,
Vinniman
'88 Highline
Perth, W.A.
Discussion Starter · #8 ·
no i just need 4 new tires and saw some rim and tire sets. i was thinking of just putting them on if i could find a set that would fit right. i saw a lot of 20" sets
