I have a new front right side (US passenger side) marker light assembly. Install is easy EXCEPT for the fact that I can't get my hand on the back side (entry from inside the engine bay) to tighten up the plastic "wing-nut" that holds it into place. Do I really have to remove the entire headlight assembly to mount this thing? The left side (US driver) is very easy and accessible.
You can remove the top of the air filter housing to give yourself a little more room, but yeah, it's tight. Don't drop the nut.
are you talking about the large diameter (~3") air flow hose/pipe that's connected to the inside fender body? that's what I need to actually remove but not sure how that comes off.
got it installed...whole headlight unit had to be slid out.
