1 - 17 of 17 Posts
2016-2018 Range Rover Sport
Hi all!
Is there any way to replace the usb/charger module that's found in the centre console with the version containing the HDMI/SIM/USB/cigarette charger?
My HSE only has the twin USB and cigarette charger and I've been told that unless I have HDMI input that android auto & apple car play will not be available.
My dealer had told me that through land rover it is not possible to buy. He said you could find a third party version. I've searched online but but able to find what I'm looking for.
Any advice appreciated.
Thanks.
Hi JoeZ,
Since you mention that you only have usb/charger in your center console, I assume you have a 2014, 2015, or 2016 RRS. Those model years do not support Apple Car Play/Android Auto. The first model year that does is 2017. Changing the inputs will not help you.
Regards,
Jose
Hi Baxterdown,
I have 2017 HSE. software version 18C installed.
I had assumed that HDMI was standard but unfortunately it wasn't.
Hi JoeZ,
The QuickGuide released by Land Rover says nothing about HDMI being required for Apple Car Play. Besides, Apple Car Play connects to USB, not HDMI. The only requirement the QuickGuide mentions is "for entertainment units with a 10" screen from model year 17." HDMI has nothing to do with Apple Car Play. You can download the QuickGuide here.
Does your screen look like the one on the pictures in the guide? If so, take the guide to your dealer and push for the update. I have the feeling the dealer is incorrect.
Good luck, keep us posted!
Jose
there are 3 distinct types of this are in our cars and as per JLR only 2 would be supported. The language used above implied that the presence of HDMI indicates these 2 supported types, not that HDMI itself is a requirement. See here: https://www.ovalnews.com/2018/10/fi...-touch-pro-updates-for-pre-my19-vehicles.html for more hints (unfortunately not proper explanations)
Sorry OP, you seem to be out of luck.
Discussion Starter · #7 ·
Thanks for the info baxterdown & totya.
So the issue I have is that my version of the UIP (as LR refer to it as) is not in the top two. As in no HDMI input.
I've been told from the dealer that I can't purchase an upgrade either.
He did say that I would be able to find something third party but wasn't able to tell me where exactly.
So if I can't purchase an upgraded version of the UIP from LR where can I find a third party version?
Existing thread on ACP and AA for 2014-2017 models.
https://www.rangerovers.net/forum/4...s-apple-carplay-update-2015-infotainment.html
The 2018s and up with the dual touch can be updated to 18c and support Apple CarPlay/Android Auto with no additional hardware.
-ThinkMac-
I have a 2017 HSE dynamic. It DOES have the HDMI input. I also have an updated In Control Pro screen (the one the 18/19 have).
However, I don't see or may not have apple car play. Not sure how to get it installed onto the vehicle from here.
Any insights? Thanks.
Need 18C software AND smartphone package. I’m getting mine done tomorrow but mines a 2018. Should be the same for yours.
Hi all, I have 2019 HSE and I have the same front console as JoeZ described. I've talked with many dealers but they all say my car doesn't support carplay. They argue that they cant upgrade either the software or the hardware. Has anyone found a solution??
I have the same problem with 2019 Autobiography model. I've neither sim card reader, nor HDMI port even if I have the touch pro duo.
I ask the dealer for the smartphone pack update but nothing!
Any solution please ??
Any updates? I still have the same problem...
You need 3 things:
1) New USB slot - FW93-19E110-AD
2) Cable from back of USB to IMC
2) Correct CCF editing
Note that the cable needs to be adapted to supply power.
You need 3 things:
Thank u Mojo
It's very intersting to create a post with details (pictures, ref,..) of retrofit.
For CCF editing, which soft can I use ?
I already use obd11 for vag cars but land rover never !!
It's not the CCF editing that's the main issue here because you can just send your CCF file to someone for editing remotely and they send the finished product back to you, then you can upload it to the car. The main thing is that you have the correct hardware and software i.e SDD for -17 and Pathfinder for 17+ cars and the relevant interface to talk to the car.
I don't really have time to write a full how-to on this but it's pretty easy for those wanting to do it. Only take around an hour to do.
1 - 17 of 17 Posts
