So after driving for 1 hr and restarting car now a restricted engine performance light goes on and car won’t go past 5 mph. Pulled over waited with engine on and the car can accelerate to 25 - which is ok for NYC streets. It’s a 2015 MYwith 23k miles! What triggered the event? Thxs
L405
Could be a number of things. Need to hook it up to a diagnostic computer and go from there. I have invested a few bucks in one and keep it in the car just for instances like this. Search here for one that will fit your needs.
2002-2005 Range Rover Sport
hi Joenyc, I think your problem , can be due to one of the issues below:
1- if there is a problem with your auxiliary coolant pump working with 12+V.
2- or if the Throttle body has failed,
3- also if the throttle paddle sensor fails,
try to pull out the OBD codes of your car using diagnostic tool and then you can go farther,
regards,
