1 - 1 of 1 Posts
I have just bought a 2010 range rover tdv8
it has started going into restricted performance mode. it only does it when going up hill accelerating.
have plugged it into diag and the only code it comes up with is p023d (map sensor)
so I took out both sensors and cleaned them this didn't work
while doing this I noticed The right hand pipe on the intercooler appeared to bleaking oil. I had a look at it and couldn’t see any splits but didn’t want torisk splitting it taking it off! Is it normal for oil to be around this? Or isit likely there is a split on it somewhere and if so could this be causing myproblem?
1 - 1 of 1 Posts
