Have replaced leaking air bags and replaced valve block and ECU.
Replacement valve block after a few weeks was not inflating right front, valve stuck permanently open.
Replaced the solenoid and had working air suspension for a few days.
Now not responding to up or down input and right front is low. Not on bump stops and no error codes that I can read with my Kicker.
Anyone seen this before or have any suggestions.
Thanks in advance.
Discussion Starter #2
Finally threw a code.
Right front valve permanently closed.
Having tried a used replacement and replaced the faulty sensor without success, I suspect a new valve block is in my future unless someone has a better idea.
Recommendations where to find a new replacement much appreciated.
The usual sources seem to be out of stock.
Thanks in advance.
Banned
If you've replaced the valve block I assume you fitted a used one? So do you have the one you took off? Get an overhaul kit and replace the seals and O rings in it and swap them back. Kit is the same as for a P38 and Scotty on here will do a set for $40.
