Anybody a hint for me how to reset the stop watch in the On board computer to "Zero" - I could not find a way to do this...strangely...
Thanks !
The information you need is in the In-Car Entertainment manual. Where else! :doh:
Although it's not clear how to reset it, you stop it by pressing the SET button, so I suspect if you pushed the SET button again, it would go to zero.
Another option would be to hold down the buton on the end of the trip computer stalk control.
I have disabled this function on my trip computer, so can't try it out for you.
Good luck!
Thank you, I will try again but problem is, I of course was checking the manual without luck, as you may know, and I tried the set button and it does not reset as it resets and immediately restarts the timer.....I'll keep looking..
Any input is appreciated.
Think I've cracked it.
With the STOPWATCH running, the symbol with a litte clock and an arrow is visible. If you press SET, it goes to 0.00 and then starts running again. If you press STOPWATCH and the symbol flashes, press SET and then STOPWATCH quickly and it remains at 0.00.
