1 - 9 of 9 Posts
Wondering if anyone know where to find these little plastic inserts for the HVAC Vents? I have searched this forum, the net, and have only been able to find the complete vent assemblies?
If I cannot find the inserts, my only thoughts are to either attempt fabrication of an insert or use a black caulking.
You don't. They are not, nor have they ever been available as a separate part. You replace the entire vent assembly as a single unit. If you are looking at black caulking you could always remove the ones existing so they match.
Might check with a Ford dealer the Fords have similar vents and the part might be available.
I was also on the same trail as one of mine is also missing , Just not taken the time to go to a Ford dealer
I superglued the remaining ones in
armozo, as noted above, they are not available as separate pieces. although built under Ford ownership, they were a BMW design and never available from Ford.
So no, doc did not find the trim pieces. You are in the same boat as everyone else, either remove all of your existing chrome bits so everything matches or replace the vent assemblies missing the chrome bits to carry the original chrome theme through.
Thank you for the feedback. I am trying to find out what to do next ... maybe 3D printing the part might be a way.Cheers
So, my friend and I tried the 3D printing route. I have two prototypes that will need lite sanding. I will also plastic prime them and spray them chrome.Hopefully, these turn out good.
1 - 9 of 9 Posts
