1 - 16 of 16 Posts
Hi all - I just bought two front eas air springs because my current front left is leaking at night and making the pump work more than it should I suspect.
My local garage wants to charge me $200 to replace both and I think that's just way tooo much dough for this job. As a result I wanted to know if anyone could point me in the right direction (links, videos, pdf) on doing this myself and how difficult it might be.
Thanks,
Rafael
There should be some directions with the new air bags. Front springs take the liner off and have new platics screws to replace the ones you break off.
bolt and clip on the bottom and two clips on the top.
pull out the old air spring and replace with new one.
I replaced my front with new air springs then my perfectly good rear air springs went dead....not sure why.
Then my collets/air connections started leaking one after the other.
I bought a coil spring conversion, now I just need to install them when I get a chance.....
Where's Kmag?
Since he is not here, you can go to the main page and follow the repair links to the proper instruction. You can also search for lots of posts on this topic. The bottom line is that it is very easy. The hardest part is reattaching the air collet so it doesn't leak. Read up on how they work before starting. I prefer to leave the fender liners on since messing with those stupid fasteners is a pain. Its possible to do without even removing the wheels.
VERY EASY! Just did one of mine following directions off this site.
Lift truck axle off the ground, put jack stands on frame,
Remove wheels,
lower axle gently,
Remove the plastic liner ( lots of screws you gotta undo),
Remove the plastic hose entering top of bag (press metal down, lift hose up),
2 clips on top of spring/bag perch, 1 13mm nut on the back left of the back holding a clip that slides out.
Fiddle the bag out, and reverse to install.
Regarding changing the Air Springs... while researching this issue, I came across the Arnott website. They have a PDF for the coil conversion. It has pretty pictures and everything! I know it's premise is how to replace with coils, but I plan on using it when I replace my Air Springs because it seems to illustrate the removal fairly well.
http://www.arnottindustries.com/manager/upload/ProductManual.asp?fileId=166
They also have a basic schematic for their air springs with show fittings, etc on the new Air Spring.
http://www.arnottindustries.com/manager/upload/ProductManual.asp?fileId=160
John
As I mentioned to you before they are dead easy to do, just follow the instructions from this website or the other posts here on this thread and you can't go wrong. I am not overly mechanically minded but was surprised at how much the Rover dealer was going to charge in labour and the fact it took me about 30 minutes to do all 4 springs (15 minutes of that was the first one while reading the printed out piece of paper I had).
Aynsley
Agreed. That seems to be the consensus. A shop I talked to tried quoting 8 hours labor to do it!
Discussion Starter · #9 ·
Success!! I *just* replaced my two front air springs and it feels pretty good to have it working again. My front left was in such terrible shape that I can hardly believe it worked for me the last few months. I was also fortunate _not_ to have caused a fault considering the rover would no longer level out and the console would just blink and blink and blink. After the replacement, it appears to be working well, albeit a tad slow.
While I found all of your tips very helpful, I used the following link to change mine (below). My process was only slightly different because I was changing the entire air sprint, not just the bladder. However, I highly recommend this page because it has helped me loads! And, with this method, you don't need to remove the tire(s).
http://hildstrom.com/projects/frontairspring/index.html
On a side note, it does appear to take a bit more time than I'd expect for the air springs to inflate... is there a general guideline of how long this should take? I'm trying to get an idea if my compressor is starting to have issues because of age (and overuse).
Thanks!
Rafael
RIP Our Friend
BULL PLOP! The local indie here can swap all four and wash the truck in an hour.
RIP Our Friend
Thanks!
Rafael
I would order the compressor seal from shupak as your compressor is most likely getting worn.
Front spring noise when turning
I have the conversion kit installed in my 99 Rover. (It was done before I bought it). I am getting a noise from the front spring area when I turn a tight left or right turn. It only happens when I am accelerating, and going uphill as I turn. (I imagine it is stretching the spring as I accelerate). I notice the Traction Control light next to the ABS light comes each time the noise is made.
I have removed and replaced the front axle assembly and the front wheel bearing, thinking the noise was coming from there. I have zero history on this truck, I got it with a frozen/ locked up front differential (due to a stupid $20 axle seal eliminating all the oil in the diff) that broke the transmission case when it locked up. I replaced the ring and pinion assembly with a used unit, and then rebuilt the transmission, replacing the broken case at the same time.
If I am facing downhill, and turn a tight turn, it does not make the noise, trac warnign lite does not come on.
Any help would be appreciated!
Thanks,
Dan
1 - 16 of 16 Posts
