I have a replacement rear seatbelt anchor (Offside Green) in the pair which sits in the middle of the double folding rear seat (rather than the single near side)
I have removed the crosshead screw visible in the plastic surround (from the top|) but can not see what is holding it from the rear ?
Do I have to remove the seat panel from the rear to access the 19mm bolt head ? The plastic cover if released may not even let me do this in a chicken or egg situation ?
I was told it was easy 5 min job at the breakers - Am I missing something ??
Lift the seat and you will see three (I think) screws through the metal base into the plastic trim piece. Remove these and the trim should come out with a bit of a wiggle. You can then push down on the leather base and use a spanner to remove the anchor. I used a ratchet spanner. It’s a 10 minute job because the access to the bolt is tight. I did this job in December.
Just checked an old seat, the screws are near the seat mounting. Here’s the holes after the screws are removed.
