Hi all, I’ve got a new (new to me) steering wheel shroud and I can’t quite get it installed with the steering wheel on. It’s very close to fitting, but not quite and I’m worried about breaking my new shroud, since it’s worth more than it’s weight in gold. I assume I need to remove the wheel? It’s a 1992 SWB.
No you don’t have to remove the wheel
Just be careful
And make sure you have all the screws
Well, I couldn’t get them on without removing the wheel. There’s little pointy parts toward the front and I just couldn’t get them past the dash trim. The wheel came off easily though.
The only problem is I could NOT get the shroud pieces to mount to the flat tabs. Just wouldn’t work. So I bent them back out of the way and everything else installed ok from there, but It’s a tiny bit loose. Way better than it was before!
