I have a 2012 HSE. Any ideas for a replacement passenger side mirror with camera? I’ve tried eBay and rangeroverparts. Ideas? A: there is no such site as "rangeroverparts.com"
Need more info... what option is the mirror for? did it die or was it hit and damaged? With such an obscure item, I would contact your local dealer can look up the actual part number. If you're not comfortable disassembling your door to find the wiring and change out the mirror or remove the remnants of the old one. Have your dealer install it for you.
2008 Range Rover L322 HSE
