I had a coolant flush and oil change two days ago. Woke up today and had no crank. Tested battery and it has proper voltage. Tapped on starter and it did crank. Bought a remanufactured starter at autozone and had trouble getting it installed but finally got it and put everything back together and still will not crank. Battery and lights work. Pulled #18 fuse and nothing. Did I miss something possibly?
Did you check your started relay for corrosion? did you jumper the power points to see if the relay is faulty?
RRToadHall, Can you help me locate the the relay? I just bought a RR project, new battery, it did start a for few days now it just clicks. (I would much rather replace the relay than the starter. Replacing that starter looks like a pain)
