I’ve had the RRS for about 2 months now. Several times I’ve had the low coolant warning appear. When I check the levels they seem fine. I’ve even topped it up a little and checked for leaks but the warning still randomly appears. Car has also gone into reduced power mode once which corrected itself after I stopped for a while.
Could this be a faulty sensor or a more serious issue. Any advice or info On what to check or how to correct the issue?
I know in the first gen sports it seems like sensor failures are common. The sensor itself is pretty much universal across all l320s, l322s from 06 to end of run. They are about $8... PCJ500030
