Hi friends,
My" machine boy" 2.5 dse have problem with the thermo visco clutch, and the engine does not reach the correct temp. Following the mechanical inspection we found the visco with malfunction.
I have to replace, and I need your help in order to do a proper job.
Can anyone help me with repair manual, or at least the section regarding the cooling system - thermo visco clutch.
The " machine boy " was born in 2000 !
Thank you in advance for your help. ;)
Doru M.
welcome on board. Search the web and download RAVE from Green Oval. It is the factory workshop manual and has all the info you would need to work on your own rig
