Hey all,
I'm working on R&R'ing the heater core o-rings in my '02 HSE and in reference to the DIY pages here it says I only need to remove the HEVAC control panel and glove box and can snake a long screwdriver through the upper right corner of the HEVAC panel opening to access the heater core pipes. I've had luck with this before on my '96 and '98 RRs where I was easily able to remove the radio as well but I'm not so sure how to get the head unit out in the '02. I know it has the two slits in the faceplate cover to presumably get a release tool into, but is there another way to get it out? I recall that on my earlier RRs, I could pop the plastic faceplate cover off of the radio and then be able to remove it. Doesn't seem that easy on the '02. Also, does the nav screen have to come out as well? I have the HEVAC control unit out and the glovebox unscrewed, but it seems that I need to at least get the radio head unit out as well to have the right angle to get at the pipe screw. ???
Thanks in advance for any help!
