2015 RR HSE
I'm trying to disable the intelligent start/stop. I've read through all the threads and understand about disconnecting the negative terminal on the battery.
The problem is, I can't figure out how to remove the panel to access the fuse area. Can anyone advise me?
Thanks much
On mine, it's pretty much just grab it at the top and pull. Hinges on the bottom. Lots going on once you get in there.
