Here is a question or poll...
Has anyone had a car starter that cause an engine code to pop up? Or any engine related issues after a remote starter has been installed?
Got a 2004 L322 HSE with BMW M62 engine. Timing everything seems to be fine, car idles and runs fine. It is a bit loud during acceleration before engine hits 3,200rpm. I am getting P0011 and P0021 codes that keeps on popping up every start up, with or without using the car starter. The starter on the car for sure is wired wrong or has a burn out relay, reason being after I start it by starter, then go put the key in the ignition, the key will not communicate with the car and unlock the ignition.
