I bought a MY 2000 car for parts in August and we have been having a devil of a time getting the wheels off. If the previous owner had needed to put the spare on at any time he would never have gotten a wheel off. Those aluminum alloy wheels all seem to corrode at the hub and get stuck. I see the service manual for the P38 and L322 both say you should put anti-seize on the hubs whenever changing a wheel. I don't think the owner's manual mention this which is a bit of an oversight I think. I guess Land Rover doesn't expect owners to be removing/replacing their own wheels.
If you ever find yourself with a flat tyre and the wheel is stuck on the hub, there is an easy solution: loosen the wheel nuts but don't take them off completely and then go for a drive, make some turns and seek out potholes/crubs etc, the wheel is sure to come lose.
Not so easy if you're working on a car that's not running...
Perhaps driving slowly ahead and jamming the brakes would break it loose? I once had to give a truck stuck in the snow with a flat tire a good yank with my pull strap to break his wheel free.
Should try out spraying some fluid film on the hub every time you take the wheel off. Stuff works wonders.
Sit down & kick the wheel rim hard with both feet ive had to do it on several cars with alloys .
That won't help the tyre much (assuming it is flat and not just down a little).
Agreed you have to be careful not to damage the rim (if the tyre's flat, I wouldn't care much about it). But it is the fastest and easiest way if you're on the road and need to change a tyre.
We finally got the fourth wheel off my parts car. Had to use a big gear puller and a pipe on the breaker bar. Did everything else including dragging the car sideways twice. I think this car had been sitting unused for maybe a year and that did not help.
