Good day to all.
Let me explain. I can find no leaks on the rig, yet the front and rear right side is always about 1.5 inches lower than the left side (both fenders).
- It happens at Access, Standard and Off-Road levels. Yet the air-compressor is not running, so it's not trying to keep up with a leak, in my humble opinion.
- I also have an intermittent amber suspension light, then the rear right height sensor (blinking red light) comes on the 4x4 display. Then of course I lose the lights on the suspension system on the console. It's not the rear-right height sensor or the harness wires. The indie shop checked the connector and changed out three different height sensors... could it be trouble with the air-suspension ECU?
- ctt
2010-2012 Range Rover Sport
Just a guess by my first step would be to try recalibrating the height, especially as you've had height sensors changed.
That was my plan this week, but life got in the way. I called the indie shop, They want to put their 'Tool' on it to see what code they get (that's 28 bucks alone). I will go early next week. I suppose to re-calibrate will be a bit more dollars but I need to have this fixed. It's driving me crazy, especially when the amber light comes on and the special programs get locked out.
