My new to me Holland and Holland came from the West Coast so no rust. On the bad side, most of the wood veneer got burned up by the sun. I pulled off all of the wood trim since I had to go in and replace the heater matrix O rings and removing a few extra trim pieces was not a problem.
Did find a number holes already cut-- so someone has been into the dash before. Not only the large round hole in the passenger side panel- but on each front right or left corner of the Heat and AirCon unit a rectangular hole was cut out. Guess I will find out what those were for at some future time.
The veneer had a light coating like varnish or poly which was all checked. Came off with a gentle scraping and sanding with 320 grit. Some cracks and lifting of the veneer are showing.
I am at an impasse as to what finish I should use. My assumption is to use a penetrating gunstock oil like Tru Oil or one of the gunstock recipes found online. I read that the Holland and Holland stocks use many coats of some form of gunstock oil. But did Land Rover go this time-consuming route for the HH???
Now, most gun oils provide a beautiful finish-(from a satin-- like the HH interior- to gloss) and will bring out the wood grain--but does not protect against sun or moisture. It takes many many coats and is very slow to dry. I have read that you can put a varnish over it- not sure how it will actually adhere.
Perhaps that is what LR did as part of the extra 30 hours-kind of doubt it.
Using a marine spar give UV and humidity protection but to look best it should be sprayed on.
Madera Concepts removes any finish using stripper and then sprays on a urethane finish. The lady I spoke to says they refinish the Holland and Holland trim the same as any other P38- but you can choose a satin finish.
Has anyone tackled refinishing their H/H trim pieces? If you have, what finish did you use?
I tried to attach a few photos but the Manage Attachments box comes up blank--- with no boxes to check so I can pull photos off of my computer. Shows that I have a secure connection- and then just a blank box.
