Is there a specific o ring safe lube you would recommend for the EAS valve block rebuild? I have some Finish Line white Teflon lube for bicycles that I think would be safe. I know it needs to be non petroleum based to protect the o rings. What have you guys used? Any particular brand?
You don't. EAS is a dry air environment. Any lubricant will simply attract any dust etc drawn in through the compressor and gum up the sealing ability.
Good to know. I will not lube. Thank you very much.
