rebuild diesel injection pump: any advice and step by step guides/videos?
Hello,
So I have changed the spill-off tubes, changed the glow-plugs and I have cleared the vacuum tube that goes from the manifold to the MAP sensor. HTe car starts much better, but.. I have discovered it leaks a lot from the injection pump. This seems at first to be out of my league, but since it is such an expensive part to get fixed in a garage or even to buy new, I would like to hear any experience of rebuilding it, hte more detailed the better, and also if someone have found inexpensive places that will rebuild it. E.g. does anyone have experience with 4land in poland?
Hope to get some good advice.
knutharald
Re: rebuild diesel injection pump: any advice and step by step guides/videos?
You can only change the top seals, all other work will need special tools for assembly.
The good news is that most of the times it fix the leak.
You can get the seal kit on ebay and there's some how to's on the web.
