Hi!
I recently clipped my RH side mirror. all that happened was the plastic backing (top half) became dislodged. I can't for the life of me get it to snap back in correctly and don't know how to make it line up with the front plastic (that goes around the mirror glass). Is there a diagram or tip or trick to fitting this all back together? No clips are broken, I just am not seeing how it all snaps back in securely, especially since the other parts are still intact - maybe I need to take it all apart and reset them all together?
2010-2012 Range Rover Sport
If it's anything like my Jaguar (in which I did the same thing) its just a plastic cover that should snap right back on.
If I were you, I'd take it off all the way then try reattaching it. That would also allow you to make sure nothing is blocking it, such a wire that could be damaged or cut if you just pushed the cover back into place harder.
