Hi, I have searched this forum to no avail. As the title states, the rear wiper stays on even with the key out. However, the arm doesn't actually move. It just stays in one spot (parked), and the motor just hums, like the gear stripped. I have to pull the fuse to get it to stop. Any suggestions would be great.
Thanks,
Chuck
2013-2015 Range Rover Sport
Pull the plug that covers the drive gear; you will see a large nut that holds the blade assembly to the drive motor. Tighten the nut, pulling the blade assembly onto the drive. My guess: it has come loose from the drive and the drive motor is trying to center the blade before shutting down. Mine came loose on my 08 twice; once on the 13.
After that, you need to hunt for frayed wiring.
