Right thats it, its going on the fire! Bl**dy Land Rover W/Shop Manuals, it supposed to cover upto 94! :lol:
Sorry, I did say assuming its a 91 MY, I checked my 93 LSE this morning and as you say its C5, but thats for the fronts, have you checked the obvious, the switches aren't very good and get worse with age, have you tried checking the continuity of the switch, it'll involve taking the underside of the dash off and steering cowling off to get to the white plug thats cable tied to the steering column and it gives you more to work with.
Did you say in another post that you're interior lights aren't working either as there's a feed for the Timer Unit (Pink/Green wire) from the interior light circuit, the purpose of the timer is to wipe the rear window 3 times after the wash wipe has been pressed, if so, seems a bit of a coincidence .
There's 2 fuses involved in the Rear Wash/Wipe, E3 seems to supply the feed to the switch, I don't know whether this is an in-line fuse or not, but it should be a White wire with a Light Green tracer from the white connector that the wiper switch plugs into, the other fuse is B5, which powers the Park Switch in the wiper motor, but I cant see that having anything to do with it.
I'm stripping mine down this weekend (weather permitting) to have look at why my heated seat switch doesn't illuminate, so I'll have a look and post.
And I thought it was only Italians cars that had bad auto electrics.
Good luck, let me know how you get on.
