My dealer told me the rear washer was not working because the hose between the pump and the motor was perished. They wanted $800 to replace. I finally checked myself, the hose is fine, the pump is fine. When disconnecting hose from motor in rear and operating pump plenty of water is pumping through. The blockage is between the inlet at the motor and the sprayers (which I've put a needle through). How do I clear this blockage
2002 L322
M62 V8 Petrol
